Eklipze3k No strings on me Staff member Parked in the garage Written a guide Joined Nov 18, 2007 Messages 18,440 Points 4,333 Location Huddersfield Apr 1, 2010 #1 Tried a quick search but couldn't find what I needed. Are these changeable with ordinary tools (like rear bearings are), or do they require to be 'pressed' in?
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Apr 1, 2010 #2 Pressed. Cheers SPD
Adrian Bravo Speedbump grimacer Parked in the garage Written 5 guides Joined Mar 13, 2008 Messages 5,542 Points 1,015 Location North West Apr 1, 2010 #3 can you buy the hub carrier with bearings fitted? might be simillar cost but easy for elkiseltzer to fit
Y ycming Patron member Written a guide Joined Oct 13, 2006 Messages 10,264 Points 1,600 Location Glasgow Apr 2, 2010 #4 Adrian Bravo said: can you buy the hub carrier with bearings fitted? might be simillar cost but easy for elkiseltzer to fit Click to expand... Fiat might do them, but silly prices.... Ming
OP OP Eklipze3k No strings on me Staff member Parked in the garage Written a guide Joined Nov 18, 2007 Messages 18,440 Points 4,333 Location Huddersfield Apr 2, 2010 #5 I wonder if Fluffy would be able to press them if I were to order hub + bearing from him ... :chin:
Y ycming Patron member Written a guide Joined Oct 13, 2006 Messages 10,264 Points 1,600 Location Glasgow Apr 2, 2010 #6 I took my hubs and front wheel bearing to a garage they pressed them in for 20 quid! Ming
OP OP Eklipze3k No strings on me Staff member Parked in the garage Written a guide Joined Nov 18, 2007 Messages 18,440 Points 4,333 Location Huddersfield Apr 2, 2010 #7 Cheers ming, Carrie's cousin is a mechanic so may be able to do it
Y ycming Patron member Written a guide Joined Oct 13, 2006 Messages 10,264 Points 1,600 Location Glasgow Apr 2, 2010 #8 Yuppy, sounds all good to go then . Just take the front hub off! Might as well replace the front arm too , they are cheap enough. Ming
