Thread Tools
Old 18-01-2005   #1
Trader Rating: 1
mase has donated!
Gary Golf Champion, SikTrix BMX Champion
drivers window problem
ok people how easy is it to remove an refit the drivers side window?
i am gettin a small scratch down the length a get a terrible squeek when i open an close it so i think there might b somethin stuck in the seal buggerin up the window.
easy to remove an check? more to the point easy to put back in?
R97 cinq 1242 <Ex Team Anthracite >
(now sold)
mase is offline Reply With Quote Quote
Old 18-01-2005   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: drivers window problem
Yup
D
Old 18-01-2005   #3
Trader Rating: 1
mase has donated!
so i am guessin it will b a haynes manual job then...
about how long would it take?
(now sold)
Old 18-01-2005   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Should I try and be more helpful?
Ok then.
The scratches I have seen on cinqs is usually some thing stuck on the felt pad on the top of the door on the outside. take the window to the bottom of its travel then push that weatherseal strip in towards the inside of the car. Should pop off easily, clean and refit.
D
Old 18-01-2005   #5
Trader Rating: 1
mase has donated!
Quote Originally Posted by rallycinq
lol nah man that was fine, was just wondering if it was easy, i got a hanyes manual in the back of the car, but neva can tell how tricky stuff is.
cheers for the help tho!
(now sold)
Old 18-01-2005   #6
Trader Rating: 3
Dan has donated!
My drivers side is amazingly bad with this. Passenger side has a load but not as bad. Its sand that gets into the sill. I'd replace mine but i cant be bothered. Will get 2 windows from a scrappy when a cinq turns up.
1.4 16v cinq complete 'ish'
Dan is offline Reply With Quote Quote
Thread Tools
(T) Punto Window Wiper Problem - please help nickfox2000 Punto (Mk1) 3 07-04-2012 18:01
(T) Tip timing problem? Akeldama Tipo (Classic) 4 01-08-2004 06:54
(G) Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 19:58
(G) drivers window jennione Marea 3 14-01-2004 02:37
(G) Punto HGT electric window problem? rds290176 Punto (Mk2/2b) 3 17-06-2003 02:23
