Technical drivers window problem
where the bloody hell is
ok people how easy is it to remove an refit the drivers side window?
i am gettin a small scratch down the length a get a terrible squeek when i open an close it so i think there might b somethin stuck in the seal buggerin up the window.
easy to remove an check? more to the point easy to put back in?
Should I try and be more helpful?
Ok then.
The scratches I have seen on cinqs is usually some thing stuck on the felt pad on the top of the door on the outside. take the window to the bottom of its travel then push that weatherseal strip in towards the inside of the car. Should pop off easily, clean and refit.
D
