Another little tip for bleeding air from the coolant system is to get a 2litre drinks bottle and fill with water, remove expansion tank cap and place bottle upside down in the tank.
Open heater matrix bleed valve and start car.....wait for water to run from bleed valve, replace bleed valve.
As the water level, due to the bottle is higher than the highest point of the system all air is forced from the engine coolant system.
If you're careful you can squeeze the bottle an force water around the system.
