jimbro1000
Established member
I've just finished swapping the motor and gearbox over on my son's Sei sporting and I'm in the process of fitting all the wiring back together but I've lost the photo I took of where everything goes.
90% of it is pretty obvious but there are a couple of points giving me trouble.
I have an earth lead on the wiring that runs behind the engine - I think it is bolted to the inlet manifold but I'd like to be sure.
There is a plate with the wiring clamped to it in much the same area. Again I thought this went on the inlet manifold but I can't figure out how or if I've got it wrong.
Can anyone post up a couple of clear shots of the wiring on that side of the engine so I can get this job finished.
(haven't even got to putting the throttle body back on but that one really is pretty obvious)
