Thread Tools
Old 15-03-2010   #1
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Steering 'dead zone', rack on it's way out?
Have just driven the Sei for the first time in months - round trip to Wakefield and back. There is a huge dead zone in the steering - about 15-20 degrees either way and a lot of knocking from the front going over bumps or potholes, made for a very, errr, interesting trip!!
The track rod ends (is that their name?) were the only bit that was disconnected during the clutch change and I don't think we got close enough to any other steering components to have been able to misalign them but is there anything I can check/adjust, or does it sound like the rack has had it and needs replaced?
Eklipze3k is offline Reply With Quote Quote
Old 15-03-2010   #2
No strings on me
Eklipze3k's Avatar
Re: Steering 'dead zone', rack on it's way out?
The nylock nuts that we removed (that hold the ball joints into the tie rod ends) were threaded, went to B&Q and got some new ones but just cannot get them tight enough as the whole assembly keeps spinning, I don't have anything I can use to separate the ball joints either so, grr
Old 15-03-2010   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
The track rod ends are tapered so you need to apply severe downward presssure as you tighten them.
Jack handle will do the job lovely.
Why did you undo them to do the clutch?
SPD
Old 15-03-2010   #4
No strings on me
Eklipze3k's Avatar
Quote Originally Posted by rallycinq View Post
SPD
Followed the guide on here
Will try the jack handle, where to wedge the other end?
Old 15-03-2010   #5
Trader Rating: 3
ycming has donated!
Ermm see the nut you got from B&Q you sure it is at 1.25 pitch ? Am sure when i was looking for those nuts, B&Q didn't stock anything that fine!
Unless you have new track rod ends and they are threaded differently.
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 15-03-2010   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by Eklipze3k View Post
Under the engine/gearbag/driveshaft.
SPD
Old 15-03-2010   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by ycming View Post
Ming
Thats a good call.
SPD
Old 15-03-2010   #8
I normally put the old ones back with some locktight, I do clean the nuts and threads.
Noel
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 15-03-2010   #9
No strings on me
Eklipze3k's Avatar
Aww man, don't tell me things like that!!! They might be new (I doubt it) but the nut threads on no problem right up the nylon, but that's when the whole ball starts to spin as I can't get enough pressure on it, even with the jack handle which btw, I have no idea how your going to get downward pressure on the rod end by wedging the handle under the engine Are we talking about the same thing?
Old 15-03-2010   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Yup, thats the gearbag end. If your handle isn't long enough (sorry Carrie) put it under the driveshaft.
SPD
Old 15-03-2010   #11
No strings on me
Eklipze3k's Avatar
Oohhhh, I think I get you now - less wedging, more fulcruming?
Old 15-03-2010   #12
Autotest Special
rallycinq's Avatar
Trader Rating: 1
If thats a word, then thats it.
SPD
Old 16-03-2010   #13
arc
this is where i stand
arc has donated!
for reference, don't do that again. you just need to take the two bolts holding the hub carrier to the strut
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 16-03-2010   #14
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
also make sure there is no wd40/grease/anything on the taper. clean it with solvent and it will tighten up with little pressure on the rod end.
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 16-03-2010   #15
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Quote Originally Posted by craigb244 View Post
they did get a soaking with Ferrisol when we took it apart that did cross my mind today whilst at work
Massive gash
Just a little touch up
Thread Tools
(T) Power Steering Motor and Steering Rack bridgit37jones Panda 2 27-11-2009 16:59
(T) Is This My Steering Rack? Steve_R Grande Punto 23 09-07-2009 18:15
(T) Steering Rack Help.. otacon Cinquecento / Seicento 1 11-06-2009 18:40
(T) Dead zone in accelerator pedal Funkstar De Luxe Barchetta 13 09-02-2009 16:30
(G) steering rack lorenzo Punto (Mk2/2b) 7 15-12-2007 01:01
