![]() | #1 | ||
Posts: 33 Thanks: 0 Trader Rating: 0 ![]() | Oil leak and poor idle ive recently bought a 2001 seicento sporting and its got an oil leak that appears to be coming from under the coil packs. Any ideas on how to fix?? |It also has trouble tickin over when the engine is warm an trys to stall but mostly idles around 500 rpm. anybody know why
![]() | #2 |
Posts: 3,254 Thanks: 120 Trader Rating: 0 ![]() | Re: Oil leak and poor idle The carrier that the coil packs live in is plugged (coaxial with the camshaft) into the side of the cylinder head. The plug is sealed with a rubber O ring, if there is lots of oil under the carrier casting the o ring may need replacing. When you get the carrier out, clean out the hole & apply lots of clean engine oil distribute it well, with a clean rag & then degrease the carrier spigot, replace the o ring and apply a continuous bead of RTV next to the o ring, replace the carrier. It might not leak, without the RTV. Noel
__________________ standard Sei Sporting except for colour matched ice scraper, screw driver, & steering wheel lock i.e yellow car spare alternator belt, clutch cable & bulb set, 2x overalls |
![]() | #3 |
Posts: 23,487 Thanks: 1152 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Oil leak and poor idle The coil packs slot in where the distributor once was, there is an O ring behind it. Fit a new one. Check for induction leaks. Your car should be MPi so can have the diagnostics done. Cheers SPD
__________________ |
![]() | #4 | ||
Posts: 33 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil leak and poor idle dont mean to be thick but whats rtv? the pipe what comes from underneath the airbox to the rocker cover has got a split in it but the insert covers that. where else can i check?
![]() | #5 |
Posts: 23,487 Thanks: 1152 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Oil leak and poor idle rtv is a silicone type sealant. With a new O ring it should not be needed. Replace any split pipes, things move around in the engine bay under load. Cheers SPD
![]() | #6 |
Posts: 3,254 Thanks: 120 Trader Rating: 0 ![]() | Re: Oil leak and poor idle Hi David is correct you should not need sealant with a new o ring, but this is a Fiat ... if the old ring has cuts or splits the castings may have rough edges, and the sealant will fix any bad symptoms, it would not be good if it gets into the oil passages. If it is leaking it may be because the crank case and cam shaft area is pressurised. It is desirable that all the pipe-work is intact and clean of any gum. I recommend replacing compromised pipes. The wee cars go ok when they work. Noel
![]() | matt1976 | Stilo | 64 | 02-03-2010 21:00 |
![]() | intervirgin | Stilo | 1 | 14-02-2010 16:51 |
![]() | swiss al | Tipo (Classic) | 2 | 04-08-2009 23:56 |
![]() | Fine Fiat | 124 Spider (Classic) | 1 | 06-08-2007 14:54 |
![]() | T140 | Stilo | 8 | 05-03-2005 21:57 |
