OK, got my new head coming then its off to get ported 'n' polished 3degree valve seats etc etc & going to fit it with a Spesso head gasket & new head bolts, so all is good!
BUT, & theres always a but.
I believe that as the car is a turbo & a hi boost at that it should run a colder plug. Done a wee bit of research into it and I think the Denso iridium as good feedback on these plugs from you guys, & IK24 looks ideal as its 2 heat ranges colder (standard IK20) and in fact is the same heat range as my integrale (1 range colder than standard) is when running higher boost, therefore higher internal engine temp!
Any one running a turbo got any thoughts on this
& I will be ordering them from the US of A as even with postage they still work out less than £30 a set or £25 combined, which I believe is a bit cheaper than in dear old Blighty, unless anyone knows different!
Aaron.
Aaron.
