![]() | #1 | ||
Posts: 182 Thanks: 0 Trader Rating: 0 ![]() | Compression Test Hi all. Going to take my Cinq for a compression test. Can you please tell me the correct readings or result of this test? Each cylinder should have the same reading? Thanks.
![]() | #2 |
![]() | Re: Compression Test each cylinder should have a similar reading. pretty obvious when problems. You should also do a wet and a dry test to test to identifty further problems. Are you getting test done for free as the guage is only about £15 and very very easy to use. |
![]() | #3 | ||
Posts: 182 Thanks: 0 Trader Rating: 0 ![]() | Re: Compression Test I am going to take it to a mechanic who works at Fiat. I am going to get charge. What is dry and wet so that I will tell him. You cannot give me an approximation of the readings? If they are close to each other it means that the engine is fine? Thanks.
![]() | #4 |
![]() | Re: Compression Test Dry is no oil added to the plug hole and wet is 1 tsp of oil added to the spark hole before testing. If the compression increases dramatically when oil is added then it means that there is a gap somewhere such as around the piston that the oil has momentarily sealed it. Sure somebody will give you a better description than i can. You do know that fiat will rape you dont you..... ![]() ![]() Last edited by Dan; 23-02-2010 at 22:11. |
![]() | #5 | ||
Posts: 182 Thanks: 0 Trader Rating: 0 ![]() | Re: Compression Test Good morning all. Did the compression test. Dry - The result cylinder 1 = 0.2 Bar, Cylinder 2 = 1 Bar, Cylinder 3 = 1 Bar and Cylinder 4 = 0.2 Bar. This guy told me that you have no water compression and even engine compression which means HG needs to be replaced and the head needs skimming. Is this info correct?
![]() | #6 |
this is where i stand Join Date: Oct 2003 Location: Manchester
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: Compression Test they all sound wrong, all far far far too low. does the engine even run? Is the timing right? Something sounds very wrong with it.
__________________ .:: 1368cc 16v Cinquecento ::. |
![]() | #7 | ||
Posts: 201 Thanks: 8 Trader Rating: 0 ![]() | Re: Compression Test 1bar is only 14.7psi, I'd expect close to 10times that.
![]() | #8 |
Posts: 3,254 Thanks: 120 Trader Rating: 0 ![]() | Re: Compression Test Yes last time I used my gauge it gave 140 PSI and 120 PSI a twin engine, stripped without a wet test The 120 PSI cylinder had too large a compression rig gap, replaced rings both 140. But even if the gauge is badly calibrated the two outers should not be much different from inners, I'd not go back to that mechanic though. Noel
__________________ standard Sei Sporting except for colour matched ice scraper, screw driver, & steering wheel lock i.e yellow car spare alternator belt, clutch cable & bulb set, 2x overalls |
![]() | #9 |
![]() | Re: Compression Test compression tests are pretty crap at anything other then looking for the obvious (head gasket) A leak down test is more reliable
__________________ 1997 - White - Cinquecento - PPC featured High boost 16v Turbo 2010 - White - Punto evo GP |
![]() | #10 |
Posts: 23,487 Thanks: 1152 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Compression Test Good morning all. Did the compression test. Dry - The result cylinder 1 = 0.2 Bar, Cylinder 2 = 1 Bar, Cylinder 3 = 1 Bar and Cylinder 4 = 0.2 Bar. This guy told me that you have no water compression and even engine compression which means HG needs to be replaced and the head needs skimming. Is this info correct? Buy a compression tester and do it yourself. Cheers SPD
__________________ |
![]() | #11 | ||
Posts: 182 Thanks: 0 Trader Rating: 0 ![]() | Re: Compression Test Hi all again. I have changed the HG and skimmed the head in summer. Now the same thing is happening buy overheating and burning oil. Did the compression test myself and the same readings come out. I bought a new one. Very cheap to buy. The rings where not replaced as I have to take the whole engine out. I think the best thing to do is replace the engine and buy a Punto 60 engine. Does anyone know a contact or seller of who sells engine of the Punto 60 in Sicily as I can go for it. Will not buy it the UK as the postage is too expensive to Malta. Thanks a lot guys.
![]() | #12 | ||
Posts: 182 Thanks: 0 Trader Rating: 0 ![]() | Re: Compression Test This is odd. No reply. Haha.
![]() | #13 |
Posts: 2,381 Thanks: 135 Trader Rating: 3 ![]() | Re: Compression Test did you have the valve stem seals replaced and the valves re-lapped?
__________________ if its cheap its generally cheap for a reason |
![]() | #14 | ||
Posts: 182 Thanks: 0 Trader Rating: 0 ![]() | Re: Compression Test No, not really. Going to strip the current engine soon.
![]() | Brin | Punto (Mk2/2b) | 16 | 05-02-2010 21:59 |
![]() | steve_uk | Bravo / Brava | 4 | 15-11-2009 23:49 |
![]() | SlinkyCinqi | Cinquecento / Seicento | 16 | 28-08-2007 21:38 |
![]() | Rob-mint-mk1-uno | Uno | 5 | 28-09-2006 14:33 |
![]() | 99sei | Cinquecento / Seicento | 48 | 22-08-2006 22:43 |
