Hi all. Going to take my Cinq for a compression test. Can you please tell me the correct readings or result of this test?
Each cylinder should have the same reading?
Thanks.
Thanks.
Good morning all. Did the compression test. Dry - The result cylinder 1 = 0.2 Bar, Cylinder 2 = 1 Bar, Cylinder 3 = 1 Bar and Cylinder 4 = 0.2 Bar.
This guy told me that you have no water compression and even engine compression which means HG needs to be replaced and the head needs skimming.
Is this info correct?
