Hi all
I have found a couple of threads about fitting an 8v head to a 16v block. wether its 1369 or 1242 block it sounds like it would work, but havent seen anyone with it installed & running.
Im gonna get a 16v engine with a broken head/valve issue very cheap from a spares car!
So im thinking as the bolt holes and channels line up, so i can make a 1242 8v and run it spi. Im not looking for any more power than a normal 1242 - so 60bhp...
I know the pistons are the main difference, but i dont think these will cause any problems? Would they lower the compression ratio?
I have a 1997 1108 8v spi, any ideas if this would have a suitable cam pulley? Or would i have to use the crank pulley & sensor etc from the 1108 block?
Im thinking about getting a punto 75 cam too while i'm at it
Your thoughts?
Thanks all
Your thoughts?
Thanks all
