Just be careful to make sure they aren't too wide - you need to keep a decent spacing between the clutch & brake - if I remember rightly the one on the left needs to be as far over as possible
Caution... Make sure the bolts don't stick out too far at the back as I found they can get caught on the carpet so I cut them down to the minimum length needed & they are now fine :slayer:
