Anyone know the tools for taking off a punto 60 tb, going to breakers this evening and dont wanna ruin it taking it off, wat bout the hoses can i simply just cut them ?
jamie86 said:Don't think you need an allen key... sure it's just a few bolts
Try and keep all the pipes if you can get them off
IIRC it's 6mmarc said:yeah you do, its around 8mm i think
You measuring the TB bore from the underside? That spacer is right, hang onto that!lolPhatAshKi said:Well i got one, its was alread off the car which is a bonus, i got the spacer to but someones written punto 1.1 on the spacer, so i dunno if its the right one, even tho the scrappy said it was.
So to check can anyone tell me wats the diameter of the hole on the spacer, my tb hole is 35mm and the spacer is 32mm is that correct?
Maybe they wrote the wrong name on it, the hole in the spacer is defenatly 32mm and the cinq one is 30mm correctarc said:if its a punto 1.1 spacer it'd be the same as the cinq..
the hole in the base of the TB should match that of the spacer..yeah
If thats the case this one i got is a sort of redish brownie colour.bloomfieldliam said:Doesn't the colour of the spacer denote which TB it belongs too?
Liam
