![]() | #1 |
Posts: 35 Thanks: 0 Trader Rating: 0 ![]() | Cooling issues... A few problems: 1. Heater works very rarely (wish is annoying as its winter) 2. Temp goes alot over 90 and occasionally up to the next dash 3. When it does get up and past the dash that's only when the fan comes on Guessing it could be a head gasket in the worse case or i could have an airlock or water pump may have gone. Just need to know how to find out wich is actually is, and how to do them. Thanks.
__________________ Driving A Yellow Fiat Cinquecento Sporting. Never Had More Fun. |
![]() | #2 |
Posts: 2,381 Thanks: 135 Trader Rating: 3 ![]() | Re: Cooling issues... there should be a bleed nipple by the heater at the back of the engine bay (central) ans one behind the drivers side right if i remember correctly, try those first if no luck pressure test the cooling system if the head gasket s one the needle should fluctuate as some gasses are getting into the cooling system hope this is some help to you Ash ![]()
__________________ if its cheap its generally cheap for a reason |
![]() | #3 |
Posts: 23,487 Thanks: 1152 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Cooling issues... It is a coolant issue, so sort the bleeding issue and report back. Cheers SPD
__________________ |
![]() | #4 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Re: Cooling issues... I had the same problem. Drained the whole system and then filled again with coolant. Works fine now
![]() | #5 |
Posts: 62 Thanks: 0 Trader Rating: 0 ![]() | Re: Cooling issues... ![]() http://www.demon-tweeks.co.uk/produc...pcode=RED80204
__________________ [SIZE=3]"If in doubt, flat out[/SIZE]" [SIZE=2]- Colin McRae MBE (1968 - 2005)[/SIZE] |
![]() | #6 |
Posts: 35 Thanks: 0 Trader Rating: 0 ![]() | Re: Cooling issues... Sorted it, had not alot of water in it, so i bled the system, put some antifreeze in and works fine now. Gonna keep an eye on my water levels and see if anything comes of it. (can't be arsed with a head gasket going) ![]() Cheers for replies
![]() | #7 | ||
Posts: 44 Thanks: 1 Trader Rating: 0 | Re: Cooling issues... more likely the rad leeking both my cinq and sei had leeks add a bottle of rad weld for the sake of £4 and see if you still loose water in a week .
![]() | #8 |
![]() | Re: Cooling issues... Don't use rad weld. It's a dreadful bodge.
__________________ M12 fund £20 |
![]() | #9 |
Posts: 23,487 Thanks: 1152 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Cooling issues... Cheers SPD
![]() | Barney vd Merwe | Uno | 5 | 22-06-2009 12:08 |
![]() | symonh2000 | Bravo / Brava | 3 | 15-05-2009 19:04 |
![]() | arc | Cinquecento / Seicento | 8 | 03-10-2008 16:32 |
![]() | Mike St Helens | Punto (Mk2/2b) | 0 | 20-03-2007 15:18 |
![]() | punto man | Punto (Mk2/2b) | 10 | 02-06-2004 17:28 |
