FIAT Auto Specialist Team
Thread Tools
Old 07-12-2009   #1
My Cinq is making some strange noises
About 2 months ago I was horrified to find out my Cinquecento's head gasket had gone, so it was repaired, along with a full service (mechanic said the entire oil and water system was completely contaminated). The mechanic told me to bring the car back after 500 miles for another oil change. I've done about 700-800 miles since then (oops). I will be sending it in this week.
About a week ago my 1997, 1.1 Cinquecento starting making some weird noises. The only way I can describe it is like a strange, whuuuring noise (think of the creepy sound that wind makes when its travelling fast, and make it a bit more 'enginey', and you got it) on the drivers side, under the bonnet (I believe it's the side the cambelt is on). The whuuring seems to increase and decrease, depending on the speed of the engine, so I'm pretty sure it's something to do with the cambelt. I don't think it is the engine, because the noise isn't coming from that area. The thing is, I'm planning to drive up to Birmingham and back on Friday, and I live in gloucester; it's about an hour drive. Would the car be ok you think if I can't get the oil change done? It drives perfectly fine, and I havn't had any problems with the whuuring...engine stays at a good temperature all the time.
Any help is appreciated
Cirris is offline Reply With Quote Quote
Old 07-12-2009   #2
Trader Rating: 3
ycming has donated!
Re: My Cinq is making some strange noises
Did yhe change the cam belt and tensioners when he did the head gasket?
If he hasn't might be a dodgy tensioners
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 07-12-2009   #3
Trader Rating: 5
fingers99 has donated!
Could be cambelt/tensioner or alternator bearings. Possibly even water pump.
If the cambelt snaps you'll be left stranded.
Keep a good eye on the temperature, join the AA/RAC (recovery) and pray for peace.
The oilchange I'd not worry about too much.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 07-12-2009   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
I presume you've been checking the oil weekly.
Rather than just looking at quantity, pop a thin rubber glove on and feel the oil beteen you fingers. Should still be brown and not gritty.
SPD
Old 07-12-2009   #5
arc
this is where i stand
arc has donated!
It'll be the cambelt tensioner or alternator belt. The belts might too tight. mention it when you take it back.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Thread Tools
(G) help my punto is making whirling noises BAUERctu Punto (Mk2/2b) 1 21-08-2009 14:26
(G) stilo making clunking noises andig Stilo 15 14-11-2008 13:36
(T) mk3 (54 reg) making noises lockdownents Punto (Mk2/2b) 0 15-05-2008 00:13
(T) Car making wooshing noises and loss of power. Phil Punto (Mk1) 7 13-12-2006 20:48
(T) Punto Mk1 Making Weird Noises!! Maybe Clutch! punto60s Punto (Mk1) 6 05-10-2005 09:13
