Old 10-10-2009   #1
Thumbs up Clutch, Handbrake and Rear shockers on Cinq 1.1i Sporting
My 98 1.1 Cinqucento sporting, got given to me a few days ago, BUT! The handbrake doesn't work as i want it to i have been told its a manufacture problem but... im a moron and wont be told haha..
also i think my clutch is on the way out an just wondering where ON THE INTERNET would i get a cheap but good one ?
And last but not least... .My rear shockers..or the back of the car makes a awful creek sound when weight put on the car... that means i defo need some new shockers...
Im studing 'Motor vehicle maintenence and repair' soo noo need to bother faffin on about labour
i just need to know where on the internet i can get these resonably cheep NOT CHEAP AND NASTY!
Cheers People .. Marcus
Marcus1100 is offline Reply With Quote Quote
Old 10-10-2009   #2
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
Re: Clutch, Handbrake and Rear shockers on Cinq 1.1i Sporting
Quote Originally Posted by Marcus1100 View Post
First off its not a manufacture problem more of a crap materials. I made my own levers in the end but soon fitted discs.
if the rear shocks work (not leaking and the back end is not like a pogo stick) then the creaking is most likely to be either the bushes but most likely either the top or bottom shock mounts.
spray a load of WD40 under there and see if it cures it. if so when it comes back just remove and put copper grease on everything that moves
edit: pretty much any motorfactor will get you a clutch. between 25 to 50quid. before i fitted a stilo clutch i ran a proper cheapo one (25) and it still looked mint after a good few K (good bit of sports use to) and its still going strong in another car
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 10-10-2009   #3
Trader Rating: 5
fingers99 has donated!
Prett much as Craig says. The handbrakes can be sorted -- see the guide -- often it's down to the elbows which stick out of the drums (and to which the cable attatches) having seized solid.
If the creaking occurs only when you get into the car (rather than driving it) it may be the infamous Cinquecento "bonking creak" caused by the springs on the end of the handbrake cable fretting against their stops. A little lubricant often helps. The fault is rumoured to have been designed in on the insistence of the Polski Pope: I've known brand new Cinqs do it.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 10-10-2009   #4
Thanks Guyss
Youve not just probly saved me some Coinagee :P
Youve saved me a headace
ill have a goo and see if it works
Thanks guyss
(G) rear shockers rab10000 Multipla 3 03-08-2009 12:04
(T) 100HP Rear shockers babbo umbro Panda 96 22-02-2009 12:05
(T) Rear springs-shockers johnson550 Marea 1 17-02-2009 17:46
(G) Seicento rear shockers mark86_02 Cinquecento / Seicento 5 03-07-2007 16:24
(T) Seicento Rear Shockers Teresa.H Cinquecento / Seicento 6 22-12-2005 15:26
