Old 06-09-2009   #1
Denmark
Seicento - Start problems when warm
HI guys, My Seicento 899 cc does not want to start after driving for more then 10-15 min. Starter kicks in but no ignition. A friend looked in with some kinda tool and said that there is no spark coming. THere are no problems when i start it in the morning, but after driving for more then 10 min it just needs some time to start again. Please, any suggestions?
sergio2u is offline Reply With Quote Quote
Old 06-09-2009   #2
Trader Rating: 5
fingers99 has donated!
Re: Seicento - Start problems when warm
If no spark and no fuel (peek down the throttle body) past the injector, it'll be the crank sensor. Otherwise, suspect the temperature sender (blue thing on the inlet manifold) or the coil pack may be breaking down when hot (cheap from scrappy).
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 06-09-2009   #3
My money is on coil packs.
It's amazing what you can do with a Hacksaw and a Welder!
signwerx is offline Reply With Quote Quote
Old 06-09-2009   #4
Unless both coil packs go together it should misfire on two cylinders, stopping completely it is the crank angle sensor probably.
It is easy to swap a coil pack if you got one, otherwise swap a crank angle sensor.
Thanks sergio2u thanked for this post
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 06-09-2009   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Stick a meter on the temp sensor and check for sensible readings.
SPD
Old 17-12-2009   #6
Denmark
Quote Originally Posted by rallycinq View Post
SPD
Hi guys, many thanks for the posts. It was a crank sensor, I replaced it and it works everytime!!! Many thanks,,,
(T) Warm Start Problem kegg Punto (Mk2/2b) 0 24-09-2007 19:24
(T) warm start problems cockerhoop Cinquecento / Seicento 1 19-03-2007 13:05
(T) Warm Engine - No Start frozensolid Punto (Mk2/2b) 3 07-09-2005 09:23
(T) Won't start when warm Daz155HGT Coupe 5 06-05-2005 18:20
(T) won't start when warm djPaul T Bravo / Brava 5 09-01-2004 03:09
