Technical Seicento - Start problems when warm
sergio2u
HI guys, My Seicento 899 cc does not want to start after driving for more then 10-15 min. Starter kicks in but no ignition. A friend looked in with some kinda tool and said that there is no spark coming. THere are no problems when i start it in the morning, but after driving for more then 10 min it just needs some time to start again. Please, any suggestions?
Unless both coil packs go together it should misfire on two cylinders, stopping completely it is the crank angle sensor probably.
It is easy to swap a coil pack if you got one, otherwise swap a crank angle sensor.
