im Axle Specialists
Thread Tools
Old 06-09-2009   #1
Error Codes: P0201/202/203/204/0351/0352
Hi guys,
ive read the above codes and need some help, the car starts for about 10 minutes ten it cuts off and will not start again till it cools down.
The codes refer to the injectors (1,2,3,4) and the ignition coils A&B, however the cause symptoms are shown as Wiring, coils, and ECM on all codes.
I have been told that i will have to replace the ECU, please advise, i would be very grateful.
I have managed to clear all the codes but the car still has the same problem mentioned above and management light keeps flashing, however the codes have not re-appered since i got rid of them even while driving the car.
The ECU Serial is: IAW4AF.M91
Its a 2003 seicento and has only done 13,000 miles.
don007 is offline Reply With Quote Quote
Old 06-09-2009   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: Error Codes: P0201/202/203/204/0351/0352
Before condemning the ECU, check that you have a permanent 12v supply to the coils and injectors with ignition on.
Coils and injectors are negative switched by the ECU so a 12v +ve supply is common to all of them.
ECUs very seldom fail, often unpluging and reconnecting it (with ignition off) will cure a problem.
Dave.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 06-09-2009   #3
Question Re: Error Codes: P0201/202/203/204/0351/0352
Quote Originally Posted by Davren View Post
Dave.
my mechanic tried unplugging as you say but it didnt work, he thinks it requires an ECU as its getting warm. thanks i will try the voltage supply.
any other ideas you may have will be appreciated.thx
Old 06-09-2009   #4
Hi
I'd also try the bonding (earthing) straps.
Check for physical damage of wiring or corrosion.
I.e. remove the fastner that holds down the lug and clean all surfaces to silver then coat with copperslip grease and remake.
If it is still doing ten minutes the ECU is hanging on..., some thing else wrong...
Noel
Think there are three bonding straps do all three...
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 06-09-2009   #5
Trader Rating: 5
fingers99 has donated!
The late type ECU (as you have) is very reliable. I'd be inclined to visually inspect the wiring, do the old start it up at night, bonnet open, and check for flashes routine (blue flashes indicate a HT leak, orange flashes a LT leak), use a single jump lead from battery -ive to somewhere near the coilpack to eliminate earth faults (very common on the Cento).
Getting the codes is one thing -- interpreting them and fixing the fault is quite another. Many garages, even FIAT ones, have the first skill but not the second. IIRC, there's yet another code for an ECU fault.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 07-09-2009   #6
Quote Originally Posted by Pep0 View Post
Hi
Noel
I have checked all the wiring, cleaned all the earthing wires and still no luck. still cutting. plugged in code reader and no codes. any suggestions
Old 07-09-2009   #7
Quote Originally Posted by fingers99 View Post
i have checked all the above, cleaned all the earth and tried with the jump lead as you suggested, still cutting off.
Old 07-09-2009   #8
Trader Rating: 5
If it's shoing no codes, there's either an issue with the code reader or...........?
My on experience goes something like this: my Sei decided to develop a fault in the middle of Southport -- a horrible misfire with the code light on. I popped it into the local FIAT who found no less than 8 stored codes, but wanted a couple of hundred quid for "further examination".
I replaced the leads and coil packs, discovered that the aftermarket induction system was effectively grounding out the HT leads, made sure that stood off and it has been fine ever since (touch wood). Diagnostic systems 0, start it up at night with the bonnet up 1.
That it's cutting out without a fault code suggests, to me, TDC sensor. Check -- when it cuts -- for spark and fuel past the injector (pull one injector, if need be).
M12 fund 20
Old 07-09-2009   #9
Simpler to order a TDC sensor and change it for caution. Saves stopping in middle of round about...
Noel
Old 10-09-2009   #10
Noel
i think we found the problem the water temp sensor can someone tel how to remove it, does it need a special tool. when unplugged the car idles fine, it stays for longer. iv just got the new switch
Old 10-09-2009   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
This is MPi so a bit of a mystery to me, but I would have though it simple unscrews once the cable plug is unclipped.
SPD
Old 10-09-2009   #12
Quote Originally Posted by rallycinq View Post
SPD
its not that simple its moulded to the plastic housing. theres hardly any room to put a spanner in
Old 10-09-2009   #13
Trader Rating: 5
The sensor (the green one) itself will unscrew, but is sold complete with the plastic bit it screws into, which -- IIRC -- clips/bolts to the inlet manifold itself. Remove the inlet mani and all will become clear.
M12 fund 20
Old 10-09-2009   #14
ok thx give a try
Thread Tools
(T) Seicento p0201 p0203 p0300 codes skydome Cinquecento / Seicento 1 31-05-2009 22:32
(G) error codes m_aver_ick Punto (Mk2/2b) 16 09-04-2008 17:51
(T) Error codes alaska Multipla 1 15-12-2007 14:50
(G) error codes m_aver_ick Punto (Mk2/2b) 3 30-10-2006 18:58
(T) error codes stuuyh Punto (Mk2/2b) 0 16-07-2004 02:30
