Hi guys,
ive read the above codes and need some help, the car starts for about 10 minutes ten it cuts off and will not start again till it cools down.
The codes refer to the injectors (1,2,3,4) and the ignition coils A&B, however the cause symptoms are shown as Wiring, coils, and ECM on all codes.
I have been told that i will have to replace the ECU, please advise, i would be very grateful.
I have managed to clear all the codes but the car still has the same problem mentioned above and management light keeps flashing, however the codes have not re-appered since i got rid of them even while driving the car.
The ECU Serial is: IAW4AF.M91
Its a 2003 seicento and has only done 13,000 miles.
