I was unable to start my car from cold today, it turned over but would not start so i called out the recovery, the mechanic sprayed some easy start in the airbox and it started and run as normal, he said this is common with punto's and a sprayof easy start has got them started, he said it may be to do with the cold start sensor or something in this area, what could be causing it not to start when cold but starts every time when it is hot ,everything must be working ok as it runs as normal once it starts, my car is a seicento shuie also i had the diognostics check a while ago and no faults came up, should i buy some easy start ready for when it happens again or is there something that is at fault many thanks.
