Technical Checking gearbox oil level - MPI Seicento SX
Manufacturers tyre data for Seicento.
899-S-SX-Citymatic:
145/70 R 13 71H (For town use only in Poland).
155/65 R 13 73T (Steel rims).
165/55 R 13 70H (Alloys).
1108; Sporting:
175/50 R 14 74H (Alloys).
I know that's what it says, but I had 165/55R13 on steel rims.
My 2003 Polish Mpi 1100 came with 145/70 on it which is listed as being wrong...???
As for wet and dry gearbox's..
Fiat probably fitted wet ones to some models just to get rid of their stock of them.
We have ourselves a mutant Seicento!
Yea a nice turtle paint job and a 1200 turbo really be a wolve in sheeps clothing.
But it is fingers suggestion that seems most resonable that they are operating a variant of JIT(just in time) parts procurement, JFI i.e. dont bother Just Fit It.
And my box took over 2 litres...
The plot thickens...
After having a look at some Seicentos for sale recently (not just for this, I'm trying to get another decent one!), I have discovered some things...
The non-sportings that have sporting gearboxes are not uncommon, it SEEMS most after 51 had them, the ones that are like this also have clear side repeators, and 165/55 13 tyres
The SXs that don't have sporting gearboxes are made in 51 plate or before, have orange side repeators (not front indicators) and have 155/65 13 tyres.
I don't know if the pattern is the same for S trim level Seicentos 'cos I've only been looking at SXs
Fingers99, your S have orange or clear side repeators?
I was referring to only differences between MPI Sei SXs, but yes I understand what you mean as in pre-2000 Seis S and SXs have 899 engines.
A wet shaft means that the inner drive shaft universal joint shares its lube with the gear box.
So if a inner gaiter 'goes' the universal might survive but the gear box probably dies, - in the 1st quarter mile, after it gets to a low level. Don't rely on the 1/4 mile, survival, it will be damaged before then...
Noel
Forgive my ignorance... does 'wet shaft' mean that the car's driveshafts are bathed in oil? I thought all centos had wet shafts. How can I tell if my 52 plate, MPI, clear side repeaters S has a 'wet' or 'dry' shafts?
If it's a Sporting, it'll be dry. Otherwise, check whether the inner driveshaft boots go straight into the diff (wet) or into black metal tube (dry) first.
If yours is wet, it's likely not to have a reverse detente.
Pep0 said:
"The thrust bearing may not last too long and you will then get back to the previous box performance."
Well, here I am in September, and the problem is now worse than before I changed the gearbox oil. No smooth change possible in any gear. First is terrible. Fifth is nearly impossible if I've accelerated a long way in fourth. 3rd and 4th won't engage without a hard push. Now I just have to find a decent clutch to go in it. I'm assuming a FIAT replacement part is the best option? As I remember someone saying on another thread that there's no advantage in a perfomance clutch except for seriously tuned engines.
Rallycinq said on another thread clutch kits are really cheap - that's not the message I'm getting from these sites!
http://www.aepdirect.com/index.php?option=shop&page=shop.product_details&category_id=1182&product_id=4440
And this website seems to list a different clutch kit for models made after March 2002 - Could that be because Fiat started fitting a different box around that time I wonder?
http://www.carparts-direct.co.uk/clutches_detail.cfm
My car was made either in Jan 02 or Feb 02. So which clutch do I need?
hi ,just remember if you drop the gearbox oil out dont go by the haines manuel to refil if replacing ,it states that the gearbox holds 2.4 ltrs ,dont think so,iv a 1108 sei abarth,more like 1.6ltrs
