I'm trying to replace the fuel filter on my seicento but am unable to remove the hose on the downstream end of the filter. I'm probably being useless but does anyone have any ideas?
Thanks for all the replies. It's an SPI. The upstream side was came off in 2 bits. The inner bit had wings you squeezed to allow the outer bit to slide off then you just pulled the inner bit off of that makes sense. The downstream side is completely different. It still looks like there are two bits in the but all the squeezing in the world hasn't helped. There are 2 flanges i suppose you could call them on the outer bit but squeezing them hasn't helped.
