Technical Fitting brake discs!!
my friend u need to get a haynes manual, aka "the bible"
if u are pretty handy with spanners i dont think it would b too hard.
and personally i would go for black diamond grooved discs, and EBC green stuff pads.
u will prob b lookin at spendin about £90-£100 for a decent set of discs an pads.
If its the same as most other cars, they're really easy. Very dirty job though. Get a copy of the haynes manual and you'll be sorted... I wouldn't expect disks to be more than £20 for standard disks... Just remember to be very gentle with them for the first few weeks, or you'll have them warped in no time!
Well easy job. While you're doing the discs you might as well change the pads too. No realy difference until you really hammer the brakes :D
Doddle and a piece of **** on a cinq. On the Sei it is slightly more complicated oweing to the wheel stud bolts have to come off too. This required the use of a long length of metal pole to hold the hub still and a hydraulic jack to to turn the spanner.
Also removing the drift pin that holds the caliper in place is easier to remove using a G-clamp and a small socket, instead of thwacking it with a hammer and mincing your thumbs and fingers.
