Technical Punto Throttle Body????
dj_mod
Doncaster/Scunthorpe, United Kingdom.
Cento Evo in his for sale ad has mod'd throttle body and injector? what sort of gains and which punto/injector? oh and what mods?
also
whats required in transfer from 1.1 sporting to 1.2? do i need any more than loom, ecu and lump/ancillaries? ive done lump swaps in mk2 scorts and helped wi me dads many kit car engines over the years so was fancyin a diy?? anything need fabricatin or is it wiring?
On-Line Wheels - Styling - Performance - Lighting
All Major Credit Cards Accepted
www.domlanemotorsport.com
I just swapped the throttle bodies over, if you do make sure you get the black spacer that fits between the throttle bodie and inlet manifold.
The black spacer gives a proven 1bhp (woopy dooo) but the throttle bodie gets rid of that flatspot between 3-3.5K rpm.
To fit the 1242 all you need is the engine, no loom or ecu!
Theres a few bits to cahnge over nothing serious and a spacer to be made for the exhaust, i'm sure Pete could help you out with what needs doing.
"The Not so Fast but Furious"
Ohh howz business? and have you managed to fix your car yert after that little off on the way back from Donny???
Dom,
Punto 60 engine drops straight in, just swap the oil pressure switch and crank sensor from the 1108, but keep the 1242 pulley as it has a vibe damper in it which you need. Exhaust needs a spacer (~10mm) or it won't clear the sump - but not too big or the lambda sensor will hit the bellhousing. Alternatively get a custom manifold and cat/decat made up.
Throttle body - watch out here as some Punto 60's have the 32mm body and some 30mm. The size can either be measured or read off the back - it's dot stamped on the flat face next to the fuel inlet pipe. I have ground the shaft down and recessed the screws on mine to get more air past, gives a definite improvement after 5000 revs.
Pete.
Cinq sporting 1242cc
http://mysite.freeserve.com/close_to_cracking_up/
http://autos.groups.yahoo.com/group/Cinqs_and_Seis/
http://www.clubcento.co.uk/
