Old 09-06-2009   #1
bigS has donated!
Ireland
MOT Fail!
Was wondering if anyone could help me! my sei failed mot today on brake balance! The rear brake balance was 36% out, the stronger being at the near side! This is the second time it has failed on this and the percentage hasn't changed at all. before putting it in the second time i inspected everything to which i thought could be the problem. I have Checked the rear shoes which are recent, i have adjust the handbrake and checked the elbows. I have bled the system 2 or 3 times just to make sure but it still is the same.
This is the foot brake which is out by the way.
Any help would be greatly appreciated.
Shannon
bigS is offline Reply With Quote Quote
Old 09-06-2009   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: MOT Fail!
Are the shoes adjusted correctly and any wear ridge removed?
Is the wheel cylinder free or seized?
SPD
Old 09-06-2009   #3
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: MOT Fail!
Is there a brake balance compensator fitted?
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 09-06-2009   #4
Re: MOT Fail!
Something wrong with slave cylinder could cause imbalance or contimination on shoe lining, or damage to drum surfaces..
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 09-06-2009   #5
bigS has donated!
Ireland
Re: MOT Fail!
Il check the cylinder this evening at some stage. How can you adjust the shoes?
I don't think there a brake balance compensator fitted unless these come standard with the sei sporting?
Shannon
Old 09-06-2009   #6
Re: MOT Fail!
I think the cinq's and the sei's have a front to rear anti lock (hydraulic) device in both circuits, i.e. left and right, but they are more reliable then the slave cylinders. So 1st port of call is the slaves and the shoes and the drums. One of the slaves will have a frozen cylinder... and you know which side, if so get new cyinder and brake union spanners.
The shows have a rustic self adjusting mechanism reliant on friction...
Noel
Thanks bigS thanked for this post
Old 09-06-2009   #7
bigS has donated!
Ireland
Re: MOT Fail!
Had a look at the car there. Appears that the front piston on the brake cylinder is sticking. Would this be enough to cause 36%?
Shannon
Old 09-06-2009   #8
Trader Rating: 5
fingers99 has donated!
Re: MOT Fail!
On the slave? That's likely.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 09-06-2009   #9
bigS has donated!
Ireland
Re: MOT Fail!
Yep on the slave.
Ok Will get a couple ordered. Thanks for the help
Shannon
Old 09-06-2009   #10
Re: MOT Fail!
I'd recommend doing the slaves both sides, getting the unions to undo is sometime difficult...
Noel
Old 09-06-2009   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: MOT Fail!
Get the short copper brake pipes too.
SPD
Old 10-06-2009   #12
bigS has donated!
Ireland
Re: MOT Fail!
Will do. Thanks a lot!
Shannon
(G) MOT fail PaulDrage Uno 12 23-07-2008 21:08
(G) will it fail mot? tick369@yahoo.co.uk Bravo / Brava 9 10-07-2008 17:35
(G) MOT fail Jaff_Fox Panda (Classic) 7 12-05-2007 21:17
MOT Fail polecat Lets Talk FIAT 5 23-10-2004 09:54
