Technical Flywheel
Technical Flywheel
mustard
nice and hot!
saff east london
Hello
i am currently rebuilding my 1242 engine, however looking at the haynes manual it mention that there is a possibility of making the timing 180 degrees out if not put on correctly. Does anyone know the correct way of putting on the flywheel? i have noticed that there is a notch in the flywheel, does this line up with some mark?
Mustard
cheers mate, thats what i thought but the haynes stated it could be 180 out? which threw me.
cheers again
As craig said, I can't see how the timing can be put out by the flywheel/crank relationship.
Crank timing being 180º (180º phase as well) out doesn't make a jot of difference with the ECU being an SPI or MPI engine. But cam timing being 180º out (90º phase!) will probablly stop the engine from working period.
If it is the crank pulley you mean (ie not the flywheel) then yes its possible to get it wrong, there is a tiny 'pip' and a small hole. It is possible to not line these up. I think thats what you mean ???
nope i mean the flywheel, maybe i am reading the manual wrong but if you look at the haynes manual chapter 2B (OHC engine in car repair procedures) paragraph 11 it mentioned the flywheel 180 out. As i said it could be me reading it wrong.
I can't find my Cinq manual at the moment but the Punto manual talks about alignment not timing. Basically if you get it the wrong way round the TDC marking on the flywheel will be 180º out, which has about as much consequence to the engine as what you had for lunch.
Unless you use it to find TDC on no.1!
So, putting it on it's head, so to speak, and if there is more than one way of putting the flywheel on, set the engine to TDC on compression on no.1 cylinder (both valves closed) -- you'll do this for the valve timing anyway -- then pop the flywheel on with the mark for TDC lined up.
The engine, as said, taketh no readings from the flywheel and really doesn't care, but you might like to be kind to subsequent human operatives.
Coming back to basics, you should always mark the position of the flywheel on the crank before removal as they will be balanced together.
It would also help on a 1242 to mark the position of the damper too.
SPD
