Boostjunky
Hi Guys,
I've traced a fuelling issue down to the small breather pipe going into the throttle body, if I blank both connections the car idles normally. If I fit the pipe it doesn't and the pipe isn't perished or split. Is there suppose to be a restrictor or one way valve in this pipe as mmine has nothing in it and i'm sure it wont vent from the throttle body to the larger breather all of the time.
Thanks from Ross
Thanks from Ross
