Well the car now starts and drives fine!
The servo is working as it should now too!
Seems the slight blow on the exhaust which was there before the HG job has got worse, no doubt due to the fact I disturbed the exhaust by unbolting the clip holding the first part of the exhaust on, underneath the car, but without undoing that I couldn't get the manifold forwards enough
Thanks for all your help everyone,
A relieved GP3000000!
One more point: I bled the cooling system cold but couldn't get more than a trickle out of the top bleed valve, whereas the bleed valve by the headlight let water out readily.
I repeated this after driving a short distance and it was the same. Top bleed valve unwilling to give up any water.
I drove a further distance and now the top bleed valve was letting out water, at a pressure too, small bubbles of air every now and then, but tons of water coming out! After a while the bubbles are getting fewer and far between - do I just stop when it's mainly water coming out, I mean, I could sit there forever with smaller and smaller bubbles coming out... Isn't the cooling system pressurised? Surely that means it needs air, because water doesn't compress?
