What did you do with the wiring?
I'd rather have fully functioning fog lights than get rid of them altogether.
I cut the wiring and insulated the exposed end with tape and then clipped it to the clip in the bumper. If I ever refit I would then put a fresh connector in.
Cinqster, how did you attach/fix the mesh to the bumper?
I used the 4 existing holes that the plastic grill type things used. I used some blacked out repair washers to hold the mesh firmly in place.
I did consider replacing them but my Sei had the later fogs on them and if I remember they were £92 for both to replace. As they are useless in actual fog I decided there was no real loss and it has cleaned the front end up a little. It could easily be returned to stock.
