With having the fan set to cold recently it's started snowing inside my Cinq, so I've been trying to remove the heater matrix (or at least slide it out a bit) to check it before buying a new one.
I've taken the three screws out but it seems to be stuck solid - I've tried cutting around the foam/gasket but I can only get at the bottom and front edges.
Any hints, other than remove the whole heater box or radweld (used it before for the radiator, only lasts so long and leaves a mess in the header tank), otherwise I might have to buy a new matrix anyway and nibble the plastic away from the old one with some pliers then clean up the box.
