Thread Tools
Old 06-05-2009   #1
Unhappy Wrong Size Wheels?
Hi all, although i have just joined i am not new to this, but its great...however i am new to posting stuff....
I have a 95 Cinq S 899cc, which i have only owned for about a month, originally just buying it for an emergency car to get to work etc, but its true what they say, they do grow on you, so i am now thinking of keeping it and modding it.....BUT, i think i have just done a catastrophic error, i have just bought some 13 rims, but i dont think they are going to fit
can some1 please point me in the right direction...many thanks
Rim Width: 5.5J
Tyre Width: 175
Rim Diameter: 13 inches
Aspect Ratio: 70
Offset: 35
Load Index: 82
Number of Studs: 4
Speed Rating: T: max 118 mph
Stud Diameter: 98
TWINSTA is offline Reply With Quote Quote
Old 06-05-2009   #2
Trader Rating: 3
ycming has donated!
Re: Wrong Size Wheels?
Gives us the tyre profile 175/XX/R13 ?
Also with ET35 (offsrt) you will need 10mm spacers at front.
The information you given about the wheels, all seems perfect for the cinq
Ming
Thanks TWINSTA thanked for this post
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 06-05-2009   #3
Trader Rating: 5
fingers99 has donated!
!0mm spacers at the front, 3mm at the rear should do it. Otherwise, I don't see any problems.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 06-05-2009   #4
Poland
Quote Originally Posted by ycming View Post
70
So the tyres will be a bit high....
SCUDERIA SEICENTO
MRodz is offline Reply With Quote Quote
Old 06-05-2009   #5
Trader Rating: 3
Yeah wheels look fine with spacers but the tyres may well need changing to something like 175/50R13
GoBe is offline Reply With Quote Quote
Old 06-05-2009   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
The tyres won't fit, they'll need changing to at least a 60 profile, 50 is better.
SPD
Old 09-05-2009   #7
Cheers guys, your knowledge and info is much appreciated.
what size tyres do you think would be best if i were to drop it 50mm/60mm. 175.50.13?
Old 09-05-2009   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by TWINSTA View Post
175.50.13?
Yup
SPD
Old 10-05-2009   #9
sorry to bother you guys again, but i'm having trouble sourcing tyres...what would be the highest profile i could go without having problems, (scrubbing etc) when dropping it 60mm.
I'm still using 13s (5.5j, ET 35) i found 155/65 R13 73T TW do you think these would be ok?
cheers guys
Old 10-05-2009   #10
Scandinavian Passion....
StoneNewt's Avatar
StoneNewt has donated!
You're probably looking at around 530mm natural diameter, or a little under 100mm of sidewall on a 13" rim or just over 85mm with 14" rims. That gives you 155/65R13 with a H (130mph) speed rating T (118mph) is a notch to low. Personally I'd go for 175/50R13 if you want to keep to 13x5.5j rims, read below if you want to know why.
At 14" 195/45R14 should fit but 185/50R14 however at 540mm will probably become very tight and hard to fit in the arches. I know this doesn't answer your question but I think it will apply to other people doing a search.
Why do you want high profile tyres?
For gear ratio reasons you'll gain virtually nothing in economy, as the engine is under low loads it'll rev freely with smaller throttle openings & thus less fuel. I know the difference between 175/50R13 and 175/50R15 was very little, if anything negative.
If it's for comfort oddly enough a wider slightly lower profile tyre will do you better as the wider tread will tend to soak up the smaller road imperfections better letting the suspension deal with larger imperfections in a more controlled manner. Something like a 205/35 will be to far and you'll have such stiff sidewalls that you'll lose what you gain but something like a 195/45 profile would be a nice compromise.
Seicento Sporting, 1.1 8v N/A, Dark grey
Seicento Sporting, 1.2 8v turbo, Yellow
Volvo V70 D5 Sport, 2.4 20v twin-turbo, Black
StoneNewt is offline Reply With Quote Quote
Old 10-05-2009   #11
Trader Rating: 3
ycming has donated!
Quote Originally Posted by StoneNewt View Post
the lower profile (170/50/13 and 185/50/14) cost a fooking bomb!!! (less common). The higher profile is much much cheaper but they don't fit right so as suggested go for the 175/50/13 mate!
Mong
Old 10-05-2009   #12
Trader Rating: 5
Part worns?
M12 fund 20
Old 10-05-2009   #13
Trader Rating: 3
ycming has donated!
Quote Originally Posted by fingers99 View Post
Part worns?
no in that size up ma bit
Ming
Old 11-05-2009   #14
Trader Rating: 5
There will be someone, but finding them will be difficult up there in the highlands.
M12 fund 20
Old 11-05-2009   #15
I hold up buses
balidey's Avatar
Trader Rating: 1
balidey has donated!
What I have found is: Cheap wheels means expensive tyres. Expensive wheels means cheaper tyres.
I got some 'free' 13" alloys but it was going to cost a 'fortune' to put 4 new tyres on at the right size. I then got some 5.5"x14" wheels and again the tyres were still expensive. I then spent a bit more on 6"x14" wheels (still quite cheap though) and then suddenly the tyres came in at about 40 each. So spending more on alloys can pay in the long run.
I hold up buses
balidey is offline Reply With Quote Quote
Thread Tools
(T) Headlight size information in instruction manual wrong? Unprincipled Punto (Mk2/2b) 8 09-03-2014 23:44
(S) Best Size Wheels For A X1/9 Brae91 X1/9 2 03-03-2008 00:24
(G) Windscreen - wrong size! alexGS Uno 10 21-07-2007 12:39
My boxes are the wrong size Randomman Leisure Lounge 3 03-07-2007 19:43
(S) what size wheels evo10 Punto (Mk2/2b) 17 04-08-2005 14:32
