mattplews
RE: Pressure sensor/switch
Hi guys,
Thanks for everyone who gave me advice on my cinq that was playing up.
Just to update you, it was the Pressure sensor/switch, on the fuel injector system. This can cause the car to under perform, rev low/cut out at about 4,500rpm and play up on cold starting.
If you have any of the syptoms above u may have the same problem, apparntly its very common and a lot of people dont notice it.
The engine management light does not always come on with this fault, mine did because it was so far gone!!!!
It cost me £130 to get it fixed but was well worth it as performance is like new! They also do a bit of fuel pipe changes that will stop the fault reoccuring, the mechanic said it should have been a recall fault as most suffer with it one way or another.
Matt
Hi guys,
Matt
