Make sure the connections between the door and the bodywork are clean. You can't miss them when you open the bonnet they are copper looking on the body with copper prongs on the door. If they look dirty, or corroded in any way take a small bit of emery or fine wet 'n' dry paper and lightly buff them up, should do the trick.
