Old 14-04-2009   #1
Simples...
hutchie's Avatar
hutchie has donated!
My 1st problem - nut rubbing!
Hello!
I recently purchased a Sei Abarth and have managed to rack up my first problem. To ease explanation see the pic below!
The nut marked with the yellow arrow is rubbing against the metal wheel behind it. I believe that there is a plastic piece (that you can see drooping below the area) which I think it has snapped and was once attached to the wheel arch liner. What I am mainly asking is do I need to replace the whole wheel arch liner to stop the rubbing, if so what part I need and an idea of the price. And if I dont need to replace it ideas of sorting this problem.
hutchie is offline Reply With Quote Quote
Old 14-04-2009   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: My 1st problem - nut rubbing!
Cut the arch liner away if its annoying you. If not, leave well alone.
SPD
Old 14-04-2009   #3
Simples...
hutchie's Avatar
Seems an odd set up to have a nut and bolt sticking through so that it could/can hit the running parts!
I wasn't sure what the bolt was there for but if it's not needed I might just cut it out.
Cheers for the help!
Hutchie
Old 14-04-2009   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
The bolt is there to hold the bottom part of that cover in place. If the bottom cover is missing or broken, you could replace it, or not bother and remove the bit of arch liner to clear the pulley.
SPD
Old 14-04-2009   #5
Belgium
i've remove that, also the plastic is gone...
did had that problem to
dendjoker is offline Reply With Quote Quote
(T) wiper problem...doing my nut!!! please help thruAlupe Punto (Mk2/2b) 9 03-10-2012 18:55
(G) locking wheel nut problem bravotony Bravo / Brava 14 26-05-2011 21:56
(T) 1st post. 1st problem tonespunto Punto (Mk2/2b) 9 23-07-2006 13:26
(G) Locking Nut Problem! MathewJonesUK Punto (Mk2/2b) 2 24-04-2006 16:07
(T) 1st Major problem! doh! Dazza Punto (Mk2/2b) 7 01-02-2005 22:20
