Thread Tools
Old 10-04-2009   #1
jiminwatford has donated!
Transferring ECU's - red key needed?
My buddy with a '97 cinq 899 is having ECU issues and we're wondering if he got the ecu, code box and a single blue key from another car would that transplant ok into his? what he's got lined up doesn't have the red key, is that essential?
James
jiminwatford is offline Reply With Quote Quote
Old 11-04-2009   #2
Re: Transferring ECU's - red key needed?
they're both from the same year, his faulty one and the donor, if that makes a difference
James
Old 11-04-2009   #3
Trader Rating: 3
gazzaman2k has donated!
as long as you get the ecu changed and have the new key to swap the transponder over there will be no problem
Project Seicento
gazzaman2k is offline Reply With Quote Quote
Old 11-04-2009   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Its only possibly an issue if the blue key looses its code and needs the red one to recode it.
At that point the McKritch chip goes in.
SPD
Old 11-04-2009   #5
Trader Rating: 3
Quote Originally Posted by rallycinq View Post
SPD
mckritch chip works on 899 and 1.1 engines tried and tested and removes the coded key problem
Project Seicento
Old 11-04-2009   #6
is this unlikely if it is taken within a certain time frame? like a day?
thanks
Old 11-04-2009   #7
Trader Rating: 3
Quote Originally Posted by jiminwatford View Post
thanks
na its hard coded into the ecu can be years if u like
Project Seicento
Old 11-04-2009   #8
So it looks like it might work? i know we could try it and see but i think it's getting posted to him
Old 11-04-2009   #9
Trader Rating: 3
ycming has donated!
Mate stupid solution, get an early cinq 899 ECU, they are all decoded so basically plug and play. Meaning you can keep your keys etc etc..
I have sold 2 already and got none left now, but find one from a scrappy, won't be expensive.
thanks
ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 13-04-2009   #10
is annoying.
BlueDan's Avatar
BlueDan has donated!
Do you have to do something in particular to make the ECU/code block forget the keys? As we've had a Sporting and two S and have never had this problem.
A fix before it happens is to have another blue key (or two) cloned (cut and coded) from the existing one, also handy if you lost one of them
I went to a Fiat dealer for the Sporting's key and they cloned an existing blue, they didn't bother with the red key at all. There are other places that do the same for far cheaper, I can't remember the name atm but they have been mentioned on here before.
Also, if you're only fitting the ecu and code block, but still using the old ignition barrel and key to turn it you might have problems with both keys being read at once, or the wrong one being read, which would mean the ECU would refuse to start the engine.
BlueDan is offline Reply With Quote Quote
Old 13-04-2009   #11
Trader Rating: 3
you want a mreg or older cinquecento s or sx they carry the non coded ecu's
Project Seicento
Old 13-04-2009   #12
minislapper has donated!
I put an uncoded ECU on mine recently (cheers Ming) and it's been great ever since.
BTW....nice to see you posting Jim. Long time no see! Moved onto something more modern now or you still got minis?
minislapper is offline Reply With Quote Quote
Old 13-04-2009   #13
Trader Rating: 3
ycming has donated!
Quote Originally Posted by minislapper View Post
Just woundering, did the key light come on with the uncoded ecu?
am sure it doesn't :P
Ming
Old 13-04-2009   #14
Hey!
Yeh i've still got a mini 16v vauxhall POWER has been off the road for yonks though. My mum's got quite a nice one i help put together
Cheers!
Old 14-04-2009   #15
Quote Originally Posted by ycming View Post
Ming
Yes the light came on and stayed on so we took the bulb out as it got a bit annoying!!
Nice mini..... We're down to one clubman estate and one mini-based kit car now (when it gets finished)!!
Thread Tools
(G) How to Code the Blue Key from the Red Key?? Please Help smurfboy0001 Punto (Mk1) 7 24-11-2018 23:17
Red key, have you needed it? satgale Polling Station 31 13-04-2007 13:01
(T) Yet another red key / blue key thing Andymac Punto (Mk2/2b) 5 16-11-2005 21:22
(G) 2000 W Punto - Red Key needed? IanB Punto (Mk2/2b) 7 24-09-2003 16:16
