fimmo said:
i know a few of you have done this and what i'm asking is how have you all got on after it was done?? i.e how reliable is your car now? would you say it was all worth it??
i'm now getting to the point where i have some savings that i could use to buy the turbo kit and i've also got a clear visa!!! but i'm not sure if i want to spend any more money on the cinq or just go for something a bit faster anyway????
i'd rather keep the cinq though!
any of you got a second hand turbo kit for sale??? if you do,pm me please! i'm def. interested but only in the low compression bolt on kit and only for reasonable money dont offer me one £100 cheaper than van aaken sell it for be reasonable!
brickfoot how did you get on with your conversion???
I didn't do the turbo conversion myself as it already had a Van Aaken Hi-boost turbo when I bought it, but having run turbo cars for the past 7 years (Renault 5 GT Turbo's, Integrale EVO) and in the process of getting to know the Cinq a bit better I would recommend that before commencing on any conversion to turbo, get a cylinder head leak down test done, it will show any faults in the head/gasket/block, and completely flush your cooling system, renew antifreeze/summer coolant with a top quality 50% mix solution, and if any doubt exists over the integrity of any hoses, clips, connections renew them now as compressed air is way hotter than air at atmospheric pressure, therefore exposing any weaknesses. The front bumper on my car has been meshed to increase air flow to the rad and the inter-cooler plus I'm in the process of sorting out a Mocal oil cooler as I believe all turbos cars should have one as the oil is exposed to the incredible high temperatures a turbo creates.
Most turbo cars have a bad rep for reliability but this is mainly on account of unreliable owners not appreciating the much higher levels of maintenance you have to do. First and foremost replace oil every 3000miles with good quality oil, but not anything lower than 10w (Castrol RS 10w 60 is ace) as it's so thin it slips past the oil seals in the turbo and burns off, plugs every 6000m coolant every 2 years or 18000miles, cam-belts half the recommend intervals before the turbo was added. And this is very important, always, let the car cool down and idle after driving it, especially if you have been roasting it as the oil needs time to cool and circulate around the turbo, if you just switch off the oil evaporates and next time you start up the turbo spins with no oil, which leads to expensive failure. I always stuck to these rules and reliable ran 188bhp 212lb/torque from a Renault 5 for 3 years as an everyday driver with out one breakdown, and it had over 100,000miles on the clock. I've only had the Cinq a few weeks now but had it up and down t London twice covering over a 1000miles without a hitch and cruising at 90mph happily, with bursts upto an indicated 120mph.
As i get to know the Cinq better I will be posting up the improvements I make on the Van Aaken kit, i.e. oil cooler, low temp rad switch to turn fan on about 10 degrees cooler than standard, once I source one etc
I can't comment on the low boost bolt on kit, but I'm sure it will be worth it but only if done properly, a half done kit leads to twice the problems :bang:
Aaron.
