Thread Tools
Old 23-10-2004   #1
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
Rear drum removal
Right, Ive just recently renewed my rear shoes and linkages.
Ive just whipped off the drums earlier to give them a slight roughening as they were a bit glazed...The passengers side came real easy...no problems at all...no rubbage on rotation, the drivers side isnt co operating at all.
There is a slight rub on this side, but that is only very slight. But I just cant get the drum off...it just wont pop over the wheel bearing.
I know one side has a non-Fiat wheelbearing (its round without the holes for the friction adjusters), and I think it may be that one.
Anyone got any clever ideas on how I can extricate the drum from the car?
arseofbox is offline Reply With Quote Quote
Old 23-10-2004   #2
Denmark
Re: Rear drum removal
Last time I had that problem, I removed the parking brake cable and then i could remove the drum, but i can be a problem..
Best regards
Hans Henrik
[URL="http://seicento.engelund-kristiansen.dk/english/index_eng.htm"]My seicento home page[/URL]
Danish_fiat_freak is offline Reply With Quote Quote
Old 23-10-2004   #3
Trader Rating: 1
Tom, i spent a good hour with my drivers side drum pulling on it (This was with the handbrake cable removed). It finally came off with some prying using anything i could find to get behind the drum.
My ebay items: http://search.ebay.co.uk/_W0QQfgtpZ1...Zpeaster2kQ5f1
peaster2k is offline Reply With Quote Quote
Old 23-10-2004   #4
Trader Rating: 10
dave has donated!
3 leg puller
Old 23-10-2004   #5
You could always use a small hammer to tap the edge of the drum as sometimes the drums sticks itself to the hub and just giving it a little tap can help it free off.
Tap one side of the drum and then the over, start at the top and them tap the bottom, do this a couple of times each and then tap the right of the drum and then the left, this generally frees the drum right off.
I hope this help you out this is what I had to do with my old drums as one of them just wouldn't come off just like you described.
Brian
Ask any racer, any real racer, it don't matter if you win by an inch or a mile, winning's winning!
DJ_Bucho is offline Reply With Quote Quote
Old 24-10-2004   #6
Winning
GhostWKD's Avatar
GhostWKD has donated!
use something like a lil bit of wood or something inbetween hammer and drum though, as otherwise the drum may shatter
GhostWKD is offline Reply With Quote Quote
Old 24-10-2004   #7
Trader Rating: 3
Schveet... Iwas gonna use the wood and hanmmer approach anyway if there wasnt a better idea. I would use a 3 leg puller, but i need to do it today, and my local frauds closes in 5 mins, any all other sources are closed!
Old 24-10-2004   #8
Trader Rating: 10
dave has donated!
too late now i suppose but tool stalls at markets and car boot sales sell sets of 3 pullers for about a tenner,
Old 24-10-2004   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Use 'universal adjusting tool mark 1' and hit the drum on to the bearing while spinning it round. This should shock it off the hub. When refitting, a small quantity of copper grease between the drum and hub should stop the build up of corrosion between the two.
D
Old 24-10-2004   #10
Trader Rating: 3
Heheehe at "universal adjusting tool mk1". Nice one
I knocked it off with a rubber hammer.
Strangely, The handbrake's worse than it was before i roughened the drums (I can spin the passenger side easily with a wheelbrace!)
That side that had the rub has no rub now, but the handbrakes crap... Im thinking ive just knocked the friction adjusters in too much. Am I \ is my logic right? Is this just a case to do the "MWC Handbrake Procedure" - that being slam the brakes on and the handbrake on just prior to stopping?
Old 24-10-2004   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Yup, remember to be going backwards at the time
D
Thread Tools
(T) rear door window crank removal newportz Punto (Mk2/2b) 14 30-09-2018 18:32
(S) Updated price list 21/04/2004 Body Stylist Punto (Mk1) 30 09-04-2005 17:02
Punto mrk1 rear badge removal??? LJB Lets Talk FIAT 4 05-10-2004 17:48
(G) Uno rear drum brakes lashlondon Uno 4 05-04-2004 23:16
(T) Gearbox Removal + Strange Noise at Rear... perksy Punto (Mk1) 2 16-02-2004 02:12
