| Thread Tools |
![]() | #1 | ||
Posts: 46 Thanks: 0 Trader Rating: 0 ![]() | Transmission Oil Checking / Change Further to my previous post re the gear change being somewhat difficult at times, i've been trying to undo the filler plug to check the level of the transmission oil. Got the correct 12mm bit for my socket set but there's no budging. Sprayed with WD-40 - still nothing. Tried using the centre part of an axle stand to add extra leverage but still no change. Anyone got any ideas? Also, when checking the drain plug, i noticed there was a little oil around what looks like a gaiter behind the drain plug - photo attached. I'm guessing this isn't good so any thoughts/advice welcome.
![]() | #2 |
Posts: 23,469 Thanks: 1148 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Transmission Oil Checking / Change That looks like a leaky gaiter to me. Top it up rather urgently, even if you can't get the drain plug out. Cheers SPD
__________________ |
![]() | #3 |
Posts: 3,254 Thanks: 120 Trader Rating: 0 ![]() | Re: Transmission Oil Checking / Change Try a can of plus gas A or other specialist thread releasing compound. Although it is messy (afterwards) you can make a coffer dam with blue tack and leave a puddle of plus gas overnight. Tap the end of the socket lever with a soft faced hammer, dont welli it. it should not really be too tight. Was the leaking oil on the drive shaft gaiter? Noel P.S. dont drive it until you get the filler plug out and get it back to the correct level, a seized box is not repairable
__________________ standard Sei Sporting except for colour matched ice scraper, screw driver, & steering wheel lock i.e yellow car spare alternator belt, clutch cable & bulb set, 2x overalls Last edited by Pep0; 15-03-2009 at 21:52. |
![]() | #4 |
Posts: 23,469 Thanks: 1148 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Transmission Oil Checking / Change Its a taper seat plug so will need a good bit of a heave to get it out, just keep a bit of pressure on it for five minutes. Cheers SPD
![]() | #5 | ||
Posts: 46 Thanks: 0 Trader Rating: 0 ![]() | Re: Transmission Oil Checking / Change Finally managed to get the filler plug to budge, after applying force for a while. Topped up with about half a litre of transmission oil so there must have been a fair amount in there. At least i now know it is full (for the time being) and that i can check and top up at will. Need to get the leak on the gaiter fixed now.....
![]() | #6 |
Posts: 23,469 Thanks: 1148 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Transmission Oil Checking / Change Drive for 100 miles and recheck the level, just to make sure. Gear oil is thick stuff and takes time to get down into the box properly. Cheers SPD
Thread Tools | |
![]() | ChrisMClark | Stilo | 37 | 01-11-2011 02:05 |
![]() | bd528 | Punto (Mk2/2b) | 5 | 20-02-2009 13:42 |
![]() | RuiG | Cinquecento / Seicento | 19 | 23-11-2008 20:59 |
![]() | pedrocinq | Cinquecento / Seicento | 6 | 11-11-2008 16:24 |
![]() | distortionrockets | Uno | 8 | 17-05-2006 12:17 |
