Interesting. New water pump recently fitted so not that. The problem started after I drove through a flood. I was driving sensibly and don't even know if the two things are connected.
I'll be honest and say that the car is very well maintained because whenever my mechanic says something is not quite right I say "fix it", so it has had some new belts, I'm just not sure which ones.
The odd thing is it other than the flood, there is nothing that has happened that could have caused this other than some kind of part failure. It always drives fine after I leave the garage so I don't think this is a mistake by the mechanic.
The bit of plastic I pulled off was rubbing against the fan belt and not the alternator belt so while that piece of plastic might be irrelevant thee may well be another piece somewhere else that is rubbing.
The noise happens with the car in neutral. Haven't tried it with the clutch engaged. Will try that when I get home on Friday.
So, I think I have replied to everyone's ideas. Thank you very much.
On Friday I shall do the following:
1. Check for more plastic rubbing on belts.
2. Clean belts with kerosene without engine running (thank you Pep0
3. See if it happens with the clutch engaged
Could it be that some water went into the distributor or the air filter?
Really appreciate these replies.
