General EXCEL codes - spaming but neeeeeed to know asap
Cinq_Sport_BiG_DaVE
BadBoi Bonnet In Da Makin
Telford
heres the dilema
do hyperlinks on excel sheets have codes???????
i have done a data base 4 college n 1 need to find codes n formulas
but i have used hyperlinks aswell as macros
soooooo
in visual basic u can see the code for macros
but not for hyperlinks
but a hyperlink must have a code somehere because there must be a code that tells the sheet that if you click this word/icon/picture it needs to go to this page or what ever
there MUST be a code!
but where
what i have done
created a hyperlink to take me from 'sheet1' to 'sheet2'
simple enough but where is the code
i need this for my testing!!!!
ty
somthing for the clever ppl
reply asap
I'm no VBA expert, but if you were to display the contents of a cell using VBA surely it would show you the actual contents rather than rendering it as a hyperlink as it does on the sheet.
Just use a macro to switch from sheet 1 to sheet 2
Display code in VB script
Use ctrl + `(key) to display formulars in excel.
Hope this helps.
Hyperlinks in word/excel are not part of VBA, they're OLE objects that invoke an action. Inserting a hyperlink is similar to inserting a WAV or AVI file into document. If you want to find out the hyper link url. Try this:
Code:
Range("A1").Hyperlinks.Item(1).Address
that will show the first URL in the cell A1, you can substitute the strings from the range array, and the item array with variables.
Hope this helps
