Its gone cause of them horns :bang:
I knew of the problem so should of got it sorted earlier
The ECU was read and it had 4 fault codes
I cant remember all of them but the main one is that it doesnt reconigse the key and wont let them put the code from fiat in that i had to get, but the car can be started and runs via by-passing the immobilser
There not so concerned that it doesnt reconigse the key cause it clearly does, so they now thinking the ECU is fried inside and something called EPROM was mentioned im guessing this is a chip inside ECU, am I right.
So by the sounds of it a costly job, but on the plus side FIAT are offering a part exchange on my knackered ECU, or if the guys mate who i'm using can repair it out it will be done that way.
Gaz will be off the road for a little while, but he will come back healthier and stronger, fingers crossed
