I have noticed that some people have fitted the Throttle Body off a punto 75 to the cinq sporting. Does it make much difference and is it easy to fit and also how much.
75 throttle body takes a bit of doing, but the one from the 60 is a straight swap and has a bigger bore. If you file down the shaft a little, it's got quite a bit more capacity over the standard one. Most noticeable over about 4000 revs.
True, true - apparently you can fit the butterfly section of a 75 throttle body to the top 'arf of of a Cento TB if you're prepared to machine it down a little.
