OK, Ta
SPD
SPD
something like this;
http://cgi.ebay.co.uk/SARD-Adjustab...14&_trkparms=72:1683|66:2|65:12|39:1|240:1318
VAD didnt fit them, but considering the injector needs the correct pressure to spray the correct pattern, i wouldn't skimp on fitting one
this is off topic but what size are your wheels??
thats how i did it. ground about a mm off a ring spanneror its a spanner in the grinder time to get it thin enough to pop through.
if that kit never came with one then why fit one? surely doing that will require it to be retuned (unless it will be anyway?)
also i fail to see how Teeing off from a line that has a pressure of 1.5bar will ever get 3 bar of pressure. it would require a extra fuel pump
explain
explain
width??
By 'eck, this thread is starting to make my head hurt
