tnt
What are the differences between 187 A1.000 and 176 B2.000 engines on the Seicentos?
because it's making a strange friction sound when I accelerate; so I intend to change it.
Well you can get noise from the belt, the alternator bearings, the crank or cam shaft, the cam belt tensioer bearing etc...
Try parraffin (kerosine) soaked rag on the belt and the pulleys, vigirous wipe. make sure the belt is within the recommended tension range.
If you remove the alternator, and the bearing(s) are damaged, a good local machine shop may be able to strip and press in a new generic bearing, and re-assemble, or you may be able to do this yourself, though not had one of these apart myself.
Noel
I will investigate with a mechanic to see exactly if the sound comes from the alternator. I will post here the results, as soon as I know something. Thank you all for the replies.
Hi
I normally use a special tools for that, dont read further
soft faced hammer and socket sized to fit, butane torch as necessary
pull them in with length of studding and socket as above, trace of copper grease on housing.
why not just remove the belt as someone said? you can usually remove them without even loosening the alternator. just turn the engine over with a socket while pulling the belt across off the pulley on the alternator.
its about 5 mins work and costs nothing
