Old 02-10-2004   #1
What is my engine and gearbox worth... (Tuned 1242 8V - 6 Speed)
Howdy people.
I'm considering upgrading my car in the very near future for something more powerful and less bumpy. Now when i come to sell the car I have the dilema whether to break the car for parts or to try and sell it as complete.
Now obviously I will be able to sell most of Punto the parts on the Punto forums, but I need to know how much my engine gearbox and running gear is worth. The car is running very very well and shifts for the small engine that it has.
Here is the engine spec:
1242 8v spi
6 Speed close ratio Box
Dastek Unichip
Fully lightened/zero balanced bottom end
Total seal piston rings
Pistons acid bathed
Gas flowed head
larger inlet and exhaust ports
Polished valves
Lightened and Balanced fly Wheel
High Lift Cam
ITG Induction kit
ITG Oil Breather
Magnecore HT leads
K&N Vacuum filter
Powder Coated Engine components
The engine has covered 14,000 miles since it was re conditioned and installed into my car. It was modified and tuned by UAD tuning based in London. Full cost paid for the work by UAD came in at approximately £2000. The engine was run in for 1000 miles before it was taken above 4000 rpm.
To ensure that the engine was running correctly, a Dastek Unichip was installed and set up at G Force located in Aylesbury. It was rolling roaded showing the following power:
Power – 83.4bhp @ 5300 rpm (figure to flywheel- recorded @ G Force Motorsport)
The car is currently runing on my 1108 ecu with the Dastek set up to ensure that it is running correctly. I also have a spare 1242 ECU with coded box, coded key spare wiring loom door locks etc. This is ideal for anyone that has a car with a coded key. Mine as it is an early Punto does not have a coded key.
The engine has not been thrashed and maintained and services by myself Meticulously. The engine has no problems at all, starts everytime and is veryvery reliable. For an engine tuned to this state the MPG is still very reasonable.
So the question is, how much do you think the engine is worth if i decide to break the car. It would make an ideal transplant for a cinq/sei and would make for a serious rapid car.
Here's a picture....
I'd appreciate your thoughts and opinions.
Cheers Russ.
http://img.photobucket.com/albums/v6...ge77_small.jpg
FCCUK refugee aka RussH
Ignore the user name, used to have a Punto - now a 20VT
puntoruss is offline Reply With Quote Quote
Old 02-10-2004   #2
Re: What is my engine and gearbox worth... (Tuned 1242 8V - 6 Speed)
I'd give around £500 i reakon. Don't suppose you know what torque the engine is kicking out do you?
MotorWorldChink is offline Reply With Quote Quote
Old 02-10-2004   #3
I've had a look at the rolling road graph. looks like its just under 90 ftlb of torque. (I think)
Reckon I would have much interest with the Cinq/Sei owners? Whats the going rate for a standard 1242 and 6 speed box?
Might consider without the Unichip. That was a fair ammount of cash on its own.
Old 02-10-2004   #4
arc
this is where i stand
arc has donated!
low mile std 1242 can be had for around £150, not sure about the 6speed box. Arent the ratios on the 6speed rather close and the final gear a bit short?
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 02-10-2004   #5
Yeh i have heard the six speed box kills your top end but acceleration is amazing. Without the chip theres nothing really special about it. Can get a punto 60 engine for £100-£150.
Old 02-10-2004   #6
how much would you sell it complete and attached to the car i want to convert mine but i aint got a clue?
Black /F/I/A/T/ Seicento 15" Wolfrace Octanes 3" s/s Peco Exhaust Few Holes Drilled In The Airbox And Drilled And Grooved Brake Discs
jimmy is offline Reply With Quote Quote
Old 02-10-2004   #7
Trader Rating: 1
nice car mate. I know a 6 speed box can be very expensive. I know that a 6 speed box form novitec for a cinq costs in the region of 899 euros (i had a quick look on there site ).
My ebay items: http://search.ebay.co.uk/_W0QQfgtpZ1...Zpeaster2kQ5f1
peaster2k is offline Reply With Quote Quote
Old 02-10-2004   #8
arc
arc has donated!
i wouldnt say theres nowt special apart from the chip, theres some serious lovin gone into that engine
Old 02-10-2004   #9
I'd be interested in the 1242 engine and the box, let me know when you know what money your looking for.
Averyone else, where do u get these punto engines & the prices mentioned in the post? anyone got anynumbers? the only places i've found are chraging £250 ish (with the throttle body)
Cheers all
dawozere is offline Reply With Quote Quote
Old 02-10-2004   #10
Quote Originally Posted by MotorWorldChink
TBH the top speed with the gear box is around 100-110mph (indicated on speedo).
And in a small car like the cinq/sei's im not sure that you would want to go much faster than that. Around down its very rapid and the box gives you that extra bit of fun. Besides I thought the gearbox was a 'must have' mod for you guys.
Is that including the wiring loom, gearbox, a recon and correct ecu to run it? Not to mention the mods.
Quote Originally Posted by arc
Cheers mate.
Are the mods that have been done are fairly common amoungst the Cinq/Sei owners?
Total mods including the cost of engine come to over £2500
Would an asking price of £500 be too much you think??
Just need to wiegh up whether its better to break or sell as a complete car.
Old 02-10-2004   #11
HP
I was only doing 80...
HP's Avatar
HP has donated!
£500 doesn't sound too bad at all - that's a monster spec engine and will go like stink in a cento.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 02-10-2004   #12
Advanced Driver has donated!
Question Re: What is my engine and gearbox worth... (Tuned 1242 8V - 6 Speed)
Just out of curiousity, why does the engine look all backwards? I've got an 899cc Sei (the 1.2 won't be any good :-( ), but my battery's near the brake fluid, the ECU's just above where the battery is and wait a moment, where's the coolant? lol, the engine's also the opposite way round!
Advanced Driver is offline Reply With Quote Quote
Old 02-10-2004   #13
The engine is the same way around. I have a punto, not a Sei so most components are in different places.
As for the engine, it would be a direct swap so would fit yours.
Old 02-10-2004   #14
the 899 to 1242 isn't a paticularly straight swap, its only the sportings that are a straight swap (1108 to 1242). I'm pretty sure thats right anyways
Old 02-10-2004   #15
I stand corrected. Im sure it could be swapped though. Unless of course the engine mounts are different.
(G) Uno Engine Swaps Chas Uno Uno 53 30-08-2017 21:57
Fiat Uno Turbo Engine & Gearbox Complete Mk1 1300 dave Auction Watch 0 13-09-2004 00:29
(T) My X1/9 twin cam conversion fiatfactory X1/9 2 19-08-2004 14:59
(T) Punto 1242cc 8v Engine + Gearbox? Two Cents Cinquecento / Seicento 0 12-05-2004 06:08
