I have a 96 cinquecento sx and every time I turn on the ignition the 5 amp fuel injection relay fuse blows. I have disconected every sensor from the ecu and it still blows. I have also taken the whole ecu wiring loom out to check for chaffed wires but could not see any. The only time it does not blow is when I disconnect the ecu. Does that mean its the ecu and if so what do I need to replace? I know I will need the ecu, but will I also need the code box and a key from a donor car?
Any help appreciated.....Thanks Dan
