Standard are 5.5" x13" 4x98 pcd, 58mm centre bore thanks to Dave's link.
You can go wider and bigger to an extent, but you need the right offset or spacers to correct.
Example, my black thing sometimes runs 6.5x15" wheels, 4x100 pcd with wobbly bolts, 34mm offset, 3mm rear spacer and the standard Fiat front spacer removed. 15"s will always be a pain in the arse without major mods though.
