keep seeing these posts on the yahoo newsgroup for the seis, but what is a bust wheel bearing? - how do I know if I have a busted wheel bearing or common faults.
A wheel bearing will give off a whirring noise before it totally fails, you should be able to hear it driving with the stereo off or by jacking the car up and spinning the wheel
£30 for a bearing, the hub comes with it. You just take the brake drum off, undo the big hub nut, slide the old bearing/hub off and slide the new one on. You don't need to press any bearings out or anything, it's that simple. Just as well 'cos they don't last long!!
Pete.
Cinq sporting 1242cc
http://mysite.freeserve.com/close_to_cracking_up/
http://autos.groups.yahoo.com/group/Cinqs_and_Seis/
http://www.clubcento.co.uk/
