- Feb 16, 2005
- 5,983
- 988
I know, I keep toying up with the turbo/s'charger idea, and putting it off, and thinking of it again.
I'm now planning the rotrex C15 charger, mounted with a custom bracket where the PAS used to be on the front of the block. I'll use a spacer on the offside engine mount as per Arron, so i can retain a 1368cc pulley, but mod the outer belt drive pulley from a 5 to 7 V.
With the charger fitted at the front i can get the charger oil supply and cooler that the rotrex needs up there as well. I will also run an IC form the charger to the inlet.
My main concern, apart from the stupid money its gonna cost, is from DaveTheTrikes experience, the crank pulley giving way under heavy load.
The rotrex is very efficient, and i won't be aiming silly, 140bhp is, but this is a major concern, especially on a superfire. If it gives, all hell breaks loose. Is there any way i can re-inforce it, or another place i can easily take the drive from?
I have two 1368cc heads, so plan to explore the one head, see how much i can take, to increase the chamber volume.
I think, that, with a decomp plate or increase the the gasket depth form a metal 0.5mm gasket, to a spesso performance (but thicker) gasket, I can acheive a nicer CR.
I'm hoping i can get the rotrex for £1200, a a few custom pieces of work, and some consumables, adn i'll have a nice setup. I have gone off the turbo idea, due to the comlexities of exhausts etc. I',m sure the costs will come out similar.
Back to the question anyway. Any way to improve the crank pulley to crank strenght.
I'm justifying all this by telling myself i'm helping the economy by spending
Anyone in the buisness who can get me a good deal on a rotrex, feel free to shout
Kristian
Kristian
